Compass module install
R.L.K.
R.L.K.
Bristol , Tn.
@Mpgrimm2
That looks like what I need , I do plan on soldering and heatshrinking Ricks sockets with the 6" + wires to my existing harness , I can measure the sockets and pins with my calipers to verify the yazaki p/n s for the post and folks future installs of this Compass Module Only thread , assuming it actually works
Thanks Mike !
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
I googled the 4 part numbers and couldn't find a vendor that showed actual stock vs getting a quote.
I did find one eBay vendor in New York that had some Yazaki pn's but not the correct ones. Perhaps they could get them though.
Edit 2: Lots of crimp tool links from the same place that may work well...
http://www.cycleterminal.com/crimp-tools.html
Up All Night Sleep All Day via my LG G4 on Tapatalk
00R/T
CT
The part numbers I have for the male pins are 7114-4100-02 (20-22awg) and 7114-4101-02(16-18awg).
Nexus Electronics out of CA has them for $0.21 and $0.22, respectively. I put together an order from them that included components for the overhead harness as well as the 4 speed fan conversion harness (so I don't have to buy the $80 Mopar one and strip it down). I got about 5 times what I need for everything to get the order up to $40 and dodge the minimum order fees. But, the lowest priced shipping option they have is $40. That's insane.
Mpgrimm2
SC
5.7L
Post up a link for Nexus if you can. And if you can post the part numbers and details for making the Mopar 4 speed blower harness in the conversion thread "that would be great... em yeah".
00R/T
CT
The Nexus website is nexelec.com.
I was planning on posting the HVAC harness stuff once I get everything and verify the parts are correct. So far I have been unable to find a source for the housing that plugs into the resistor. It's not an issue for me because I bought a used one with a pigtail, but it will be for others.
Mpgrimm2
SC
5.7L
Even if you can post up the PN's without supply source it's helpful. I will hopefully be able to add the info to the picture or drawing.
R.L.K.
R.L.K.
Bristol , Tn.
Damn , I love this forum! I'm so glad I found the www.ramforum.com
Sometimes I spend 2+ hrs a day just reading stuff ...
R.L.K.
R.L.K.
Bristol , Tn.
These are the correct pins and sockets posted above by 00R/T for the 20/22 wire , I measured them with my digital calipers and the specs from the above drawing are spot on .
So the green connector behind the drivers vents definitely Do use these pins and sockets .
Thanks guys !
I just edited my above post #4 , frustrated that I'm not having a heading displayed ?
@Mpgrimm2 , did you ever get your compass figured out Sir ?
Mpgrimm2
SC
5.7L
I just edited my above post #3 I think , frustrated that I'm not having a heading displayed ?
Nope, mine still only displays a compass heading when it wants to, maybe 30-50% of the time. (Did the same with the factory RA2 as well).
At some point I plan on re-seating the connectors at the module and behind the dash but I will likely wait until ib get around to putting in the HomeLink version.
R.L.K.
R.L.K.
Bristol , Tn.
@Mpg , Fwiw it's supper easy to get to the green connector behind the drivers air vent , no tools required , hands only .
When you get there the sockets on top and pins on bottom ( if the same as my truck) are at the #1 , #2 , & #8 locations .
At the compass module end #1 goes to #1 @ the connector , #2 (ground ) goes to #8 @ the connector , and #3 goes to #2 .
Hope this helps !
☆☆☆☆☆EDIT☆☆☆☆☆☆
Do you know the P/N of your module ?
R.L.K.
R.L.K.
Bristol , Tn.
Turns out the p/n compass module I have is good to use on my 14 Express and about 300 more vehicle configurations per mopar , and quirkparts.com also says it's a good for my truck as well .
R.L.K.
R.L.K.
Bristol , Tn.
Thanks Mike !
I did check fuse #80 with my meter , it was good
I just purchased another compass module from Avgas in the classifieds here.
We must be missing something that's not normal , (like the ghost fuse for the radio near the brake booster ) not sure what it could be ...
I had CV2 FLASHED , I verified the fuse , I installed a known good p/n module , I completed the electrical circuit per tech authority against my vin # ( Padre had the tech authority subscription and he was nice enough to run my vin and pm me the compass system for my truck )
Not sure on what to do next other than to try another module , which I should have this Wednesday.
00R/T
CT
Do you have dashes where the heading should be or nothing at all?
R.L.K.
R.L.K.
Bristol , Tn.
No sir , I do not ?
I'm thinking the dealer realy didn't flash in the CV2 code ?
I've got another module coming this week . If that doesn't work I'm gonna get the CV2 Flashed again ...
00R/T
CT
If you see nothing, I think it's an issue with the configuration and not with the module.
Maybe somebody here got their codes set before installing the module and can comment. Back when I had my standard cluster I used my tool to set the BCM option to display heading and it showed up in the cluster with dashes.
Mpgrimm2
SC
5.7L
On my truck's RA4 it at least displays -- (dashes) when i don't have a compass signal.
(converted from stock ra2 & overhead console).
kg93
AZ
No sir , I do not ?
I'm actually hoping you get this to work because i would like to do the same thing. I even have the -- on my new premium cluster where the compass would display. May be a stupid assumption but do you have the screen setup to show the compass in one of the corners?
R.L.K.
R.L.K.
Bristol , Tn.
I have the 3.0 cluster , I'm trying to get it to display on my RA4 8.4NA Radio. I do plan to install a premium cluster some day though .
R.L.K.
R.L.K.
Bristol , Tn.
Stupid question , does the compass module signal have to go through the cluster and then the cluster ensures the heading display on the radio ??
Will a heading display on the 3.0 cluster ?
Do I need a premium cluster to get the compass heading to display on my upgraded RA4 8.4NA?
Thanks for any feedback guys , I'm just brainstorming here .
hunterjohnson93
