Stevearino
Hey all,
I swapped out the 3.5 for a 7 inch screen/gauge cluster, reset the odo, idle hrs, and drive hrs. I had the compass in the upper left of the screen but there were 2 dashes instead of N,S,E,W, etc. I changed it to time setting, then figured, since my 3.5 had the compass, why not this? I went back in to change it back to compass and try to figure out why the compass was only showing dashes, and now it's not even in the menu where you can change what is in the upper left corner of the screen. It's a 2018 Ram 1500 Express. I'm thinking it's something to change or show present in alphaobd, but I can't find the compass in the BCM menu of alphaobd.
Has anyone ran into this, and if you fixed it, what did you do? I'm also thinking something may have come unplugged from behind the headunit when I took that out to hard wire in a dash cam.
