First off, there is a low pressure safety switch that protects the compressor from low freon. If you don't already have enough freon charging the system, that safety switch will remain open and your compressor will not kick in. What I am going to describe will get your compressor running but be aware that there are moving parts under the hood!
So... Get a piece of wire a few feet long. WITH THE ENGINE OFF, wrap one end of the wire around the positive post on your battery. Find the wire coming out from behind the compressor clutch, then find the wire connector. Disconnect that wire connector. Then put the end of the wire connected to the battery into the clutch side of the connector. You should see the front of the clutch pull in and hear a good healthy click. Pull the wire out of the connector and the clutch should relax and you should hear somewhat of a tick. Repeat it a couple of times to make sure. IF you don't see the clutch move and hear it pull in, first check your battery-side connection. When you get the compressor clicking, let's get things moving.
Start your engine, set the AC to MAX, temp to polar bear. Go back to the wire from the battery, poke it into the clutch connector. It will pull in and the compressor should spin. Hook up your freon kit and put some freon in the lines. Follow the kit's instructions until the system is starting to look right.
Now let's see if the system is working... Turn off the engine. Remove the wire from the battery and the clutch connector. Plug the clutch connector back into it's original wire. Start the engine back up. If the compressor pulls in, everything is working just like it is supposed to and you can continue adding freon until the system is correctly charged.
If the compressor still doesn't pull in on it's own, go back to step one and add more freon. If you end up with a full charge and the compressor still won't work on it's own, you have some other electrical problem that will require more diagnosis. But you first need to get enough of a charge that the AC system's safety switches will allow the electrical part of the system to operate.
