Considering a RAM
WarrenRam
N/A
N/A
All the bravado expressed here about the Hemi when you come right down to it is pretty thin.
I'm not 100% sure that sentence will go down too well around here.
loveracing1988
Clarkston, MI
technically it is a "long block" i believe...and i figured if the chevy 6.0 and ford 6.2 are commonly refered to as big blocks, the 6.4 might as well be one too lol
Sent from my SCH-I510 using Tapatalk 2
Long block is what the dealer would get to replace your motor if it needed replacing. A long block is a complete motor minus accessories, intake, etc.
regularcab2500
Buffalo
5.9 Magnum
no especially since i learned to drive in a durango with a built 5.7 hemi that smokes camaro ss and beamers like theyre cigarettes..no competition in performance but his truck even ***** on mine haha
and everyone i know refers to the 6.0 as chevy's big block v8 even though the block is not that big
loveracing1988
Clarkston, MI
The last big block built was the 496 8.1 in the GM HD trucks.
regularcab2500
Buffalo
5.9 Magnum
yeah i looked it up its an L96 small block i guess i'll just start doing my own research instead of listening to the so-called chevy guys at work haha..we got pretty off topic regardless though my bad
sport654
I was in the same boat as you, but wound up going with the Hemi & I'm glad I did. I drove them back to back & the Hemi was just sooo much better IMHO. For the few miles extra MPG's in wasn't worth it as far as I was concerned & as mentioned above the resale market will be much greater with the Hemi. Have you ever noticed how many Hemi's as compared to Pentastar's there are on the lot? There's a reason for that. BTW I'm averaging close to 19 MPG combined driving, but I do drive conservatively.
Andy578
Ontario, Canada
2014 Outdoorsman
If mileage is a consideration go to Fuelly.com and check out real world returns for both the Hemi and the Pentastar. The separation between the two based on the reports found on this site is that the average mileage difference is 3-4 mpg. Depending on how many miles you drive per year that can amount o a difference of about $60-$75 per month or $720 to $900 per year.
I am in the exact same spot as you. I am deciding between the Eco-diesel and the Pentastar and right now I am leaning to the Pentastar. All the bravado expressed here about the Hemi when you come right down to it is pretty thin. The Pentastar 0-60 is about 7.5 sec. and the Hemi is about 6.9 sec. not that much greater. Payload the Hemi is at 1,421 lbs. the Pentastar is at 1,750 lbs. - these are Ram's own numbers from their website look it up. Towing the Hemi is at 8,350 lbs. and the Pentastar is at 7,300 lbs. both using a 3.55 axle and from Ram's website for my needs the difference is not abig deal. So the difference between towing and acceleration is minimal and the Pentastar has better payload numbers.
the gap gets bigger when you add 3.92 axles and 3.55 is only available with the 6 speed which imo is a pretty big step down from the 8 speed which is only available with 3.21 or 3.92
joshhhh
