Cracked Center High Mounted Stop light with camera
bluelinerak
Alaska
6 Cyl 6.7L Cummins Turbo Diesel
I have a 2017 Ram 2500 Laramie with center high backup light and cargo camera. I cracked the plastic cover on the light. Is it possible to just replace the clear plastic or do you have to replace the entire assembly? I can't find any parts numbers for anything but the entire assembly.
Mopar 68523966AA​
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
I seriously doubt you'll find that from a dealership. I'd check with salvage yards, ebay, or aftermarket if I were in your shoes. No way I'd pay dealer prices for one of those.
B
bluelinerak
Alaska
My thoughts as well. I've been looking but not much luck. Even without the camera they are $500+ . I need to take mine off and see if the assembly comes apart.
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
You didn't say which model HD you have, but the non-camera CHMSL for a 2017 Ram 2500 CTD is about $45 before shipping...
The illustrations are poor though, and I can't tell if they look similar enough to be able to swap that section from the non-camera light to your light.
B
bluelinerak
Alaska
Thanks for the info, unfortunately it won't work with the camera and the clear lense off a non-camera assembly won't fit.
Orca
