Cracked Center High Mounted Stop light with camera
bluelinerak
Alaska
6 Cyl 6.7L Cummins Turbo Diesel
I have a 2017 Ram 2500 Laramie with center high backup light and cargo camera. I cracked the plastic cover on the light. Is it possible to just replace the clear plastic or do you have to replace the entire assembly? I can't find any parts numbers for anything but the entire assembly.
Mopar 68523966AA​
mikeru
Super Moderator
Moderator Supporting Member
2020 Limited
Hemi 5.7L non-Etorque
I seriously doubt you'll find that from a dealership. I'd check with salvage yards, ebay, or aftermarket if I were in your shoes. No way I'd pay dealer prices for one of those.
B
bluelinerak
Alaska
My thoughts as well. I've been looking but not much luck. Even without the camera they are $500+ . I need to take mine off and see if the assembly comes apart.
mikeru
Super Moderator
2020 Limited
You didn't say which model HD you have, but the non-camera CHMSL for a 2017 Ram 2500 CTD is about $45 before shipping...
The illustrations are poor though, and I can't tell if they look similar enough to be able to swap that section from the non-camera light to your light.
B
bluelinerak
Alaska
Thanks for the info, unfortunately it won't work with the camera and the clear lense off a non-camera assembly won't fit.
KAKA
