I have a 2007 5.7 4x4 that goes through all the motions to start except the starter quits almost immediately after engaging. Like if you were bumping the engine over. I can release the ignition from start and try again about 3 times with the same result. After that I have to turn it off and back on to begin the start attempts again
I can turn on the ignition and jump the starter turn the key to start for a second and it will crank on over normally start and run fine
It has new crank and cam sensors and a verified working TIPM
I am wondering about the ignition switch but also the key fob start doesn't work just honks horn once so
I am curious if something may be amiss there
