DatacomGuy
Anyone make their own? Have dimensions by chance? I'd like to make my own if possible.. rather then dump out $200 for someone else's box..
if you know how to work with fiberglass go that route...you get the most air space with a fiberglass box.
If it was me... i would do the fiberglass route also.
on these trucks i place a piece of 3/4" mdf over the cubbies. trace the outside shape and cut. i make it like a ring so its only about 1-1.5" wide (the inside is hallowed out). make 2 of these to get some height. glue them, nail them together. protect the cubbies so the fg will come out. i like to use a tinfoil since it will form to the car and it come out easily. some will use like a painters tape. put your rings down and glass them to the foil. i will usually do 2 layers in the truck and once hardened i will do another 3-5 out of the vehicle. make a top piece to the box out of mdf carpet it and call it good!!
its a lot easier than you thought. the problem is getting enough fg and resign for the job. DONT get the stuff at a home depot type store. the problem is the resign has a shelf life and they dont go through it fast enough. online look into US Composites
I'm almost sold on trying this. Need to read so much more first.
Estimated cost for trying this?
Ill be installing 2x JL W6 10s.
