Cruise Control issue ?
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Any of you know what fuse for the cruise control on my 2015 1500 ?
The index sheet I have does not list the C C so must be buried with something else
In the old days each item was listed lol
Thanks
Ken226
Washington State
THANK YOU
Tried it a few minutes ago and it now works :O
BUT great to know what fuse
Booked mark it
I think just about everyone who has a 4th gen either has had the cruise control quit working, or will have eventually. Or, so i hear.
Last year mine started doing this. After a few forum searches, I learned of the ole smack the steering wheel trick.
Slap the steering wheel just above the button, at a downward angle.
I had to do that about a dozen times last year, then just as suddenly as the problem arrived, it went away. (knock on wood).
turkeybird56
Central Texas
THANK YOU
Booked mark it
Dang Navy dem guys Neva read manuals. lol. J/K.
RamInfo
Utah
5.7L HEMI
If the cruise control indicator light isn’t popping up in the display when you turn on cruise, just simultaneously press and hold for 5 seconds the cruise+ and cruise- buttons. After releasing them, turn on cruise control again and it should work.
Best,
RI
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Best,
RI
Thanks I will try that if it happens again !
Check last night and it now works again !
turkeybird56
Central Texas
Navy +++ "Port Hole Lovers", roflmao. MY very inane sense of humor this am. Must be a pain thing.
Swabbie, smack it with a Hammer, we'll get it to work.
RamDiver
Marlborough, Ontario Canada
2021 DS
I had my CC fail to operate a couple of nights ago during a short drive, but it worked OK driving home a few hours later.
I couldn't remember which buttons to hold, tried several unsuccessfully.
I'm hoping to not experience this again but look forward to testing this reset method, if it fails again.
turkeybird56
Central Texas
Refer to post #9, lmao.
turkeybird56
Central Texas
Dis NAVY can not see any words w/o a Magnifying glass lol
I could not find it on the index I had but easier to find on the one posted !
HEY I am a frigging Old Salt lol
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Best,
RI
My CC was out again today and slapping the steering wheel did not help !
BUT Hitting the + and - did so will see what tomorrow brings !
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Best,
RI
Tried the CC this am and still working since I hit the + -
So will see how long it works lol
Thanks again
Any vehicle with throttle by wire does not have a separate cruise control module, I think just about every vehicle built in the last 20 years or so are throttle by wire.
Cruise control is done electronically with the ECM. If it doesn't work it's most likely a button issue or there's a fault code.
skidoo
Edmonton
ANOTHER Solution
2015 1500 - I spray all CC buttons with WD40, and it works for a year. My theory is the button contacts inside get a little corroded or dirty.
Bonus- The button labels buff up so you can read them again.
Cham
Southern MB
6.4 hemi
Have this on my 2019 2500, parked outside on a hot day the CC won't respond either. I toot the horn and everything works again. I suspect it might be the clockspring in the steering wheel. They could never reproduce the problem at the dealer so they wouldn't replace it under warranty. Since the horn trick works for me, I have never looked into it farther.
