Cutting the springs
OutlawTrucker
Meansville GA
Cummins 6.7
When cutting them use a 4" grinder with a cutoff wheel. Do not use a torch. The excess heat will weaken them.
HKkid
Missouri
Looks good man...and maddog why would you have to save money, when all you have to do is cut them? But on your 2008 it won't be possible because you have leaf springs in the rear.
TheMaddog
DFW
Damn. Forgot about those. My bad. Haha
TheMaddog
DFW
And like taking them out cutting them, and putting them back in and putting everything back on
Big Boi
S. Fla
^^ same thing. I had a '97 f150. That thing was awesome. Had 225k miles on it before we sold it.
How hard was it to do this mid? I'm thinking of saving some $ and cut em
You have leafs in the back. you cant cut them. The +09's have coils all around.
trev
trev
I used a torch and it didn't weaken them to the point where you can tell. The ride is actually exactly the same besides it's actually more comfortable now that it doesn't feel like I'm leaning forward alittle.
Rogan68
Lancaster, TX / Winchester, VA
6.7L Cummins G56 DRW 4WD
He means that the torch takes the tempering out of the spring, and it will become brittle.
Not "peanut" brittle fragile, but it does take the strength out of the steel, unless the metallurgy is treated correctly during the process (like placing the uncut metal into very hot oil, and bringing it up to a high temperature slowly, then cutting it, then back into the oil and lowering the temp back down slowly.
It's a long, arduous process, so most of us just whack the **** off with a cut-off wheel and call it done.
you may or may not experience a problem with them, down the road, as the 'spring' life will be reduced.
Big Boi
S. Fla
It's a long, arduous process, so most of us just whack the **** off with a torch and call it done.
What he said
