8.4 UAs update help (solved)
justin4102
Fort Worth, TX
2020 ram 1500 Bighorn 8.4 UAs. Story goes like this I wanted to update the software. Obliviously it has not done it ota. I got the software https://desk.infotainment.com/portal/en/kb/articles/uas from here. I put it into the root as directed (unzipped of course) it's a fat32 MBR thumb drive. Plugged it in waited 10 minutes nothing (truck was idling) I unplugged the battery waited an hour plugged it back in still nothing. Any ideas what I might be doing wrong. TIA
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
>> Is this a on 4th Gen classic with 5 lug wheels or new body style 5th Gen?
>> What radio application version is the radio currently on?
(Not firmware version. It's in the dealer menu... Key in run, Press and hold: Temp Up + Temp Dwn + Front Defrost for 5-10 secs)
>> Did you read the related/similar TSB (tech service bulletin) for how to install it?
Hopefully you're not trying to install an incompatible version. (Those files are for 4th Gen classic Panasonic 4c radios only)
J
justin4102
Fort Worth, TX
also I realized I posted the wrong link. https://desk.infotainment.com/portal/en/kb/articles/uas this is what I was following sorry. I suppose I misread the files. Yes its a 5th generation bighorn 8.4 non nav. No updates were pushed as it did not recognize. I opened the dealer menu and the attached is the only information I saw. I would go and find the TSB you are referring to.
Mpgrimm2
SC
5.7L
since that's not a 4th Gen Panasonic 4c radio, those files, (from this thread) are Not For Your Truck and why the radio doesn't recognize it.
J
justin4102
Fort Worth, TX
Yeah I did not mean to post that link. I updated the link that I was actually following. Either way, they look like the same files is there a 5th gen update guide that I am missing?
Mpgrimm2
SC
5.7L
No forum guide, and I don't have the 5th Gen stuff ... Check the build sheet/window sticker and verify your radio model, but I think it may be a 5th Gen UAv non nav radio. (UAq & UAs are 4th Gen 4c series radios)
Infotainment had "related links" at the bottom of link you already posted for the UAv section.
J
justin4102
Fort Worth, TX
got it. I found the information I need. I will close or delete the post. Thank you for all your help and time.
Mpgrimm2
SC
5.7L
Don't delete/close it... That helps no one else.
Please post what you did/what worked for for your radio model for others.
