Cv axel help.
BigBlue05
Eads, Tennessee
Is there a trick im missing to get my cv axel back on. The one I bought seems to be too long. I can't get it to bend enough to fit back on the diff.
ad80721
Sarnia, ON
What is the part number for the cv axle? I had to change one on my moms Chev Trailblazer. Had to remove the knuckle to change it. The cv axle should snap into place with a faint click. Than slide the spline end thru the wheel bearing/knuckle. Attach the lower ball joint first, than the upper.
joshhhh
