Hi guys hows it going ?
I have a strange problem with my ram, Yesterday i was working under the front end and i noticed the cv joint on the passenger side had a ton of play in it so i picked up a new one and when i put it in and got things back together i noticed the same amount of play in the new cv axle. Im not sure what to think about it or what the problem could be so i thought i would see if anyone has any ideas .
P.S
i know i got the shaft over the little press ring on the shaft coming out of the diff , but to me it looks like the shaft that goes into the cv from the diff should be longer so it would remove the play in the cv joint but thats just a wild guess .
any help would be wonderful and thanks for the help in the past you guys rock
P.S
