Cylinder 2 misfire
Grumpster
Richmond,va
I keep getting a cylinder 2 misfire code and I have done everything from plugs all the to changing intake gaskets. Still can't get rid of light. Any ideas?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
First off welcome to RF. Have you swapped the coils from number two to four and see if the code fallows? That will rule out the coil pack. How do the plugs look? Miles on the engine?
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
Also you gotta push down real hard on the wire boot to get the CLICK you need. Coil packs require some finnese too and inch pounds of Torqing. Kenneths idea is the check all though. Changing the Intake Gasket on an 04 might be a good idea as that is on my 2012 list! Good luck.
G
Grumpster
Richmond,va
I moved the coil. Replaced the secondary ignition and I made sure to click the wires down and still misfire. I'm stumped. Only has 85k
G
Grumpster
Richmond,va
I will once I get off work. Brand new plug tho I dont they even have 150 miles on them yet
HemiBabe
DFW
what kind of plugs did you use?
harleyowners0709
i had the same problem.when i took it to my mech.he said they are noted for breaking valve springs.boom when the took of the valve cover cyl num one gad a brooken spring the truck still ran wiyh a skip showing mult.miss fires code 300 and 301
G
Grumpster
Richmond,va
i put champion double platinums. the other day the light randomly cut off for a few hours then popped back on and still showing cylinder 2 i havent pulled the plugs yet ( has two per cylinder.)
TheSatinPumpkin
Robles Junction/Three Points AZ
2004 Dodge Ram
5.7L
pull the covers and check the springs and push rods. Might as well get that one out of the way. Also just check the wiring harness around the coil for any frayed wires.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Grumpster see your in Richmond Va hit me up if ya need a hand.
Arturo Rojas
