Dash Cam Location
Cheese-whiz
Wisconsin
Took my dash cam camera out of my Tundra last night, and want to install it in my new to me 2020 1500 Laramie. Wondering if anyone has a thought regarding the location I’m considering. I’m thinking of mounting it on the driver’s side, way down low - sort of in that bottom left corner area. I’d like to keep things cleaner looking now that my truck is so nice. It has a rear camera too but I’m not sure I have enough cable because I’d have to get to the other side of the rear slider. I’ll measure later.
Full disclosure: I’m hesitant to install any of it though because seem buttoned up pretty tight. On the Toyota, running the cable was easy because it all just sort of “mashed” into the pillers and under floor trim pieces. I think all those areas seem much tighter and would require removal.
Mb7640
Fountian hills az
Does your dash camera have a app so you can place it somewhere then look at it real time? Im sure it will work just will not get the full picture of other cars. Its not hard to remove the pillars just use plastic tools once the bolt is removed.granted I have a warlock so maybe a bit different. Mine is behind the rear view mirror. I have the battery packs that power it under the drivers seat. Goodluck
markabby
Monticello, Kentucky
2020 Limited
i placed mine just below the rear view mirror on the windshield. however, i had to run the cable for the rear facing camera behind all the trim along the head liner (very easy..the trim can be opened just enough to hide the wire all the way to the back)
but, the power cable i just let it drop down to the 12v cigarette lighter on the top of the dash. I'm using a Redtiger dash cam. They do have a separate harness to run into the fuse box but i never bought that.
i've noticed that some mount their cameras on the passenger side windshield at the very top.
C
Cheese-whiz
Wisconsin
I have a vantrue n4. I bought the hardwire kit and tapped into the fuse block. It has a safety built-in, where if the camera is draining the battery too low,it shuts off. I did that so it had motion and collision detection when the truck was off. Honestly, it worked perfectly for a few months.
Dredger
SE Ohio
I'm not sure I'd want the camera that low. Mine is center of the windshield up against the rearview mirror and it still picks up a lot of the hood. Ran the rear camera wiring along upper windshield (in the headliner) to center of the back slider (mounted to the frame in the center of the sliding window). It takes time and patience, but all the wire is hidden either in the headliner or whatever may be up against the headliner (like the rear window frame).
C
Cheese-whiz
Wisconsin
I appreciate the responses! I mounted the camera low just to see if u could, and I agree, it just doesn’t seem right. I’ll put it up by the mirror if I install it at all. Thx again
19DarthBane88
Twentynine Palms, CA
5.7 Hemi V8
Where did you place your rear view camera? I just installed a dashcam, but can't figure out the best placement for the rearfacing camera
markabby
2020 Limited
i placed mine just below the mirror. it doesn't block that much of the view. But, they do recommend placing them at the top near center of the passenger side.
your choice. I should add mine are the suction cup mount type. What i found was if they're in extended periods of hot sun, they will lose their grip and fall. Some are 3M adhesive mount, but, i wasn't crazy about having almost permanent glue on the window.
The rear camera i showed in the other post is adhesive mount.
