DODGE dealerships used to order dash mats for anyone that wanted one
They will now give you the name of the company & you have to do the ordering
I think that you will find that every 4 door cab uses the same sheet metal from the "B" Pillars forward
Pick any year
, lets keep it real simple, from 2009 - 2018
you can measure the front doors from a 1500, 2500, 3500 & you will see the doors are the same size, it does not matter if the door was made for a Tradesman or a Laramie.
( I did not mention the Standard Cab or Mega Cab front door, only because i never measured them. but i would not bet against them being the same or different )
All they change is the interior trim, basic or fancy
The dash boards are also the same on the same year Ram, some just have a different bezel or different instrument panel
All the parts are interchangeable
