Dealer feeding me bs
raff18
Sudbury canada
2019c
So I have been having a hard time starting my new warlock. I have had to boost the truck once and the voltage gauge sits high. I was at the dealer and after a bit of a fight they replaced the battery under warranty. But the charging system is still is high. they say it’s ok but from what I know 14.2 while running is where u want to be. Not 14.9 and I have even seen 15.3v. Guess I have to fight them some more. 6B98FF9F-9DD4-471A-85D1-D9652303CC20.jpegBE589D5F-4A69-4317-BBDB-A8B3996AE7D8.jpeg
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
Sorry--hope things get worked out. Maybe one of the Ram techs on here will see the post and give you some guidance as to the problem your having.
Jay
Random_Walk
...what's this bolt do? *plink* ...oh.
Out
2017 QC 4WD SLT
Pentastar 3.6
IIRC 14.whatever volts is fine for charging, since battery chargers often pump that much into the battery... I would still fight the dealer to fix the issue, but I think it might be somewhere in the starting circuit (or perhaps something in the TIPM is preventing it from starting?) A half-volt or so DC isn't going to get in the way of starting a vehicle, nor will it hurt anything.
I suspect the problem lies elsewhere; you just have to beat the dealership over the head and keep insisting that it won't start. It'll help if you can nail down certain conditions that trigger the non-starting condition (temperature, precipitation, etc.)
DRkNESS
South Jersey
Op where are you located ?
CVX20
Ont,Ca.
2019 Classic Express
I wouldn't put too much faith in the gauge.They're not that accurate.The one plugged in is probably more accurate.A good DVOM or scan tool would be even better.14.6 volts is a normal high but as long as it's under 15 it won't boil the battery.
Gero
Ontario
My battery was replaced last year under warranty too. It would be dead after 2 days of sitting in the cold. Dealer here tried to charge me $270 for it. I had to give his head a shake. The service clerk then admitted it was an honest mistake. Yeah right....he woulda taken my $270 had I been an uninformed owner.
Once the warranty ends and this battery craps out, it'll be Costco batteries from now on.
Jaywoo
Ward, AR
2018 & 2024
Both Cummins
It could very well be that you just had a bad battery. I personally wouldn’t sweat it unless it goes through another battery.
gofishn
Iowa
hemi 5.7L, 345 cu in
O'Reilly's store brand, re=badged East Penn/Dekka AGM Battery
Sam's Club AGM, another rebadged Dekka, East Penn
or
Batteries Plus Store tyad yada whatever X2 battery
indept
South Jersey
battery is covered under warranty?
Yes under the 3yr/ 36000 mile warranty.
Here's what they put in mine on saturday no charge (excuse the pun :rolleyes:). 31000 miles and 2.5 years since new.
turkeybird56
Central Texas
So I have been having a hard time starting my new warlock. I have had to boost the truck once and the voltage gauge sits high. I was at the dealer and after a bit of a fight they replaced the battery under warranty. But the charging system is still is high. they say it’s ok but from what I know 14.2 while running is where u want to be. Not 14.9 and I have even seen 15.3v. Guess I have to fight them some more. View attachment 192564View attachment 192565
BECAUSE U made me curious. Just went outside and started up MY 19, switched gauges to Volts, 14.5 // 14.6 Truck owned since Aug 2018.
T-Bird
SOLER
NM
Put a voltmeter on the battery, with truck running, and see what that reads.
misfit77
If you continue to have issues...RAMCARES is here on the forum. they tend to help with dealer issues.
TheDude266
Canada
2019 Ram 1500 Classic
Pentastar V6
If I have an issue with my Dealer I always go to the mothership.
Bring the issue up with FCA Canada in your case perhaps.
It's amazing how the attitude of a dealer changes.
Good Luck
