Diablo i3
That lowered 4x4
Salem nj
Hey guys, I've recently broke my diablo in tune 3 with a hemi fever tune. I purchased another in tune 3 and re downloaded the hemi fever tune to it. My problem is I think I have to reset the PCM to be able to re download everything. But honestly I don't know what to do.. Any advice would be nice, also the truck is a 2013 express with the 5.7.
Thanks!
ram1500rsm
Trabuco Canyon, CA
You'll have to contact Diablo if you didn't revert back to factory using your old device, Your PCM is married to the one you broke otherwise.
joshuaeb09
Medina County, TX
Thanks!
Are you sure the original is completely broken ? I know my i3 is a finicky POS, but after enough imposing my will upon it it eventually works. Getting all of my tunes loaded up was a nightmarish process that would make the device appeared bricked until I removed the offending tune from the USB drive and tried again until success. I would ***** at diablo to get you squared away.
That lowered 4x4
That lowered 4x4
Salem nj
The old one is completely demolished, I dropped something on it while moving some stuff around the garage. Im not sure if I should just get a new PCM, they aren't that expensive. Might just end up doing that
joshuaeb09
Medina County, TX
I wouldn't. Diablo should be able to get that PCM back to stock either with some files to go onto the i3 or via shipment back them. I would hit them up and let them know your original i3 got killed and you want to use the replacement on the truck.
That lowered 4x4
That lowered 4x4
Salem nj
Ok cool, I will contact them and see what's what with the whole situation
