Diablo Trinity Update - 1r09g
LB3711
Trumbull, CT
3.6L V6
then should I update? I have stock sized tires.
LB3711
Trumbull, CT
3.6L V6
ok cool. I might just to keep it updated. I have to do it later. Its warning me about low battery voltage and where I have it parked right now I can't start it.
300MAG
Not sure what other changes from f to g but I thought they made changes in the tunes when then went from e to f.
Sent from my Samsung Galaxy-S3 using Tapatalk 2
Thor09
Northern PA
I updated mine to g on Friday before heading out of town. After reloading my tune, I tried using both quick adjusts and modify tune but both said tire size change failed. I know it has update g. I'll try again this week. At least I know that the tuner is updating my tire size and speedo even though it says failed but I had hoped this update would fix it for good.
fastNugly
fastNugly
Toronto, ON
2012 Dodge Ram Sport CC
Mine said the same thing till I checked options and it was still on version 'f'
Had to go back in and re load it. Checked before I went out and it loaded.
Update.
My speedo is bang on now. I had to take a tape measure to my tires and punch in that tire height in the diablo and all is A OK!
LB3711
Trumbull, CT
3.6L V6
i did mine and Im happy I had no errors just loading a tune. It loaded the canned 93 tune and modified 93 tune without and problems. I haven't tried tire size since I have stock tires.
a_guerrajr
Houston
HEMI 5.7
So I just bought a used one.
Will I need to re-register on their website. I think it has the F version, and I do have different tires, so G version is a must for me.
Do I just go to their website, download the .exe and let it update?
fastNugly
fastNugly
Toronto, ON
You need to download the DS downloader first on your comp and then register it on the computer if the download doesnt automatically pull itself to get the latest firmware.
Was you tuner unmarried from the previous truck?
Thor09
Northern PA
Update.
Good call man, thank you. I watched update 'g' on the computer upload but never actually checked the unit itself
Thor09
Northern PA
Andrew thanks! I got update g now and tires updated properly
Gardenfan
Chetwynd, BC
Still says tire update failed. But reloaded 87 performance, turned off traction control on dash only. Leaves some nice strips now just punching it from a stop or slow roll.
Sent from my galaxy s3
fastNugly
fastNugly
Toronto, ON
Same thing happen to me and when I went into options, the 'g' update did not load in.
If you're getting that error, this is most likely the case.
Check it out.
Weird, it says tire update succesfull, but when i check it, it still reads not set!
Take your tape measure and enter that measurement in. It is usually 1" less. So if 35" enter it as a 34" and it will bang on.
I had the exact same issue as you till I dropped it down 1"
a_guerrajr
Houston
HEMI 5.7
Yes it was un-married from it.
I get it today, so i'll play around with it.
KAKA
