Distributor Vacuum Advance replacement
LouisMacc
Hello,
I'm struggling to replace the vacuum advance on the distributor.
I have a 1986 W150 5.2.
The manual says to pry up a reluctor thingy as one of the first steps. I can't pry it up. It looks like it's secured with a snap ring inside a collar.
Has anyone else replaced a vacuum advance control?
How did you do it?
Should I just replace the entire distributor?
Thanks in advance.
Daw14
South Florida
Remove the clip.
Find someone who has some mechanical skills to help guide you.
Why are you changing the advance ?
What are symptoms ?
LouisMacc
LouisMacc
Remove the clip.
What are symptoms ?
I'm stuggling to remove the clip. It doesn't look like any snap ring I'm familiar with.
Been many years,but if i remember right it's just a split ring,and i used to use 2 small screwdrivers one on each side of the split,and spread the ring enough it'd slide up and out of the groove.They can be a real bi atch though
LouisMacc
LouisMacc
I can't get that ring out, even after removing the distributor. I'm just going to buy a new distributor, O'Riellys have them for $120. I am worried that they won't fit right.
Reticle918
