DIY Diesel Particulate Filter (DPF) install
darrellthomas
Cummins 6.7 Turbo
I did this. Wanted to share/document for anyone considering the same.
I have had my 2020 Ram 2500 Cummings 6.7 Turbo, 125000 miles for about a year. I got the dreaded DPF full, and nothing would work to clear it. It would not regen on it's own. The dealer wanted about $4-5k to fix/replace the DPF. I found one online for about $1700 and decided to tackle this myself. "It is just FOUR BOLTS" says the salesman!
Super carefully made sure it was the right part for my VIN number, and ordered this DPF.
This took a bit longer than I expected, and as of now, I am vowing not to do any more work under the truck without a lift.
1. Remove spare tire, and heat shield. Remove exhaust pipe. Remove muffler. 5 electrical connectors to the muffler, just be careful and take your time with these. Rubber hangers--total PIA. Three words to make this happen. Lube, lube, and lube. Ok four words: Get THIS TOOL. Best $14 I've spent. For the lube, grease works well. Also-- transmission jack is your friend. I borrowed one from a neighbor.
2. Remove DPF. I ended up removing a support cross bar that supports the transmission, but I think I didn't need to. More rubber hanger frustration, and the bolt on the ring that connects the DPF to the turbo was crazy rusted. I ended up cutting it with a Dremel tool, and found a suitable substitute for the bolt and nut at the hardware store. Don't damage the actual connector ring though-- it's $120. Carefully remove electrical connectors. 2 from O2 sensor, 2 temperature probes, 2 control module connectors. Remove 2 pressure measurement hoses. Again, transmission jack is your friend. Save the tattered gasket to take to the local auto parts store to compare for a new one ($15)
3. Take the control module off of the old DPF and put it on the new one. Nearly every bolt was rusted and broke off. Another trip to the hardware store. I don't go to the hardware store without one of these or these. For the DPF that I got the pressure tubes were a bit smaller than the original, so I had to get new clamps to clamp it down so the rubber hoses fit properly.
4. Install new DPF. With a transmission jack, and various pieces of wood, I was able to hold the part in place while I hung it on the rubber hangers and connect the front end with the clamp ring. Funny how these rubber hangers go ON WAY EASIER than they come off. Reconnect all electrical connectors.
5. Install muffler. Don't forget the provided gasket. Install remaining tailpipe, heat shield, and spare tire.
6. Inspect for proper installation and leftover tools. I usually put some time between the work and the inspection. Go inside, take a shower, eat lunch. Then do an inspection with a cleared head.
7. Test drive. This is where I'm at right now. An OBD2 monitor helps. The DPF is no longer full, but it is in an automatic regen, and the readings are going down with each drive. I will drive a long 2-hour highway drive tomorrow and see if it goes to zero. The DPF is brand new, so I'm not sure why it even needs a regen at all.
I will follow up soon. I hope this helps if any one else decides to tackle this. BTW, the old DPF does seem to be pretty black and full of ash. I will try to clean it out and maybe keep it as a spare if it cleans up nice.
mtnrider
Georgia
For clarification, there is no "muffler", that is the SCR you removed.
Did you perform a DPF replace reset in the ECM? That needs be done as well. You can use AlfaOBD to perform it or pay a dealer to do it (if they will?)
nlambert182
Huntsville, AL
Out of curiosity (and not saying it was wrong), but why did you remove the spare tire? I've been able to remove and replace my entire exhaust system on all 3 of my 6.7s with the trans crossmember and the spare tire in place. Might save you some time.
You can remove the rear section of exhaust behind the DPF and then slide the DPF back to clear the crossmember.
D
darrellthomas
Cummins 6.7 Turbo
Thanks guys. All good inputs, this is why I am here! Hopefully this thread will save someone else some time too.
I have a licensed version of AlfaOBD —from AlfaOBD.com (on my laptop). It is connect to the truck via Bluetooth to via OBDlink2 MX+. Maybe I am missing it, but I cannot see where to do the DPF replace/reset. Any clues?
mtnrider
Georgia
I don't have my phone on me right now but I'll post it later when I get home. From what I understand there is a database of differential pressure measurements that needs to be reset when replacing the DPF so it starts fresh. I've done it before so I know it's there (or at lest it was at one point)
D
darrellthomas
Cummins 6.7 Turbo
Thanks for the input mtnrider . I will take a look at changing the pressures when you post.
I did find the “DPF Replacement” option in alfaOBD.
Here is a drill down to where it is (for me): Windows 11–> AlfaOBD 2.5.5.0 with OBDLINK MX+ (model MX201 version 3.2) —> Active Diagnostic —> DPF Replacement.
However, it balks at me and says, “No data received from ECU/Interface or data is corrupted…”.
Searching another forum here, it looks like I need a security bypass cable required for any changes on 2018+.
Thoughts on driving the truck for a few days until the cable gets here?
D
darrellthomas
Cummins 6.7 Turbo
Very good points! I think if I had a lift to work under, I would have approached in differently.
nlambert182
Huntsville, AL
I did it in the driveway all 3 times and with no jacks. It definitely does suck. Bench pressing the DPF is a chore for sure.
Yes, if you have a 18+ you need the bypass cable. Not sure what will happen if you drive it until it arrives, but if it isn't giving you the dreaded 150 mile to dealer service light, you're probably ok.
D
darrellthomas
Cummins 6.7 Turbo
Ha! Thanks for the clarification. Working on vehicles USED to be much simpler! I do have AlfaOBD to do the reset, I am just waiting on my Security Gateway Bypass to arrive. I don't understand why I have to go through all hacks and jailbreaks to work on MY truck! This is exactly why I do not have a John Deer tractor, and got a MUCH simpler tractor because the the "Right to Repair" issues they have set up, but I digress.
mtnrider
Georgia
Yep, thats it.
Probably fine to drive it, it just might regen when it doesn't really need to would be my guess (night not do anything at all)? I have a 16 so didn't need the security bypass cable
Goose55
Ajo, AZ
Cummins High Output 6.7L
I envy you guys that have the skill, tools and know how to replace a DPF because it looks like I am facing this issue. The Dealership I purchased it new from wants my truck because it has such low mileage. I will miss the truck very much because I never felt so safe behind the wheel of any other truck.
