DIY radio removal & integrate after market amp
DisturbedGator
ok so today i went ahead and installed my system. 2 kicker CVT10's and a kicker zx750.1 amp. I only documented the removal of the radio and installation of the PAC chr3 amp interface. the system sounds awesome i just need to get some seat spacers so i can fold my seats back down.
Step 1: remove rubber mat in tray above radio to reveal two screws.
step 2: remove trim piece around 115v outlet to reveal screw right above outlet. the trim piece has a little notch on the bottom of the opening to slip in a screwdriver
step 3: remove lower rubber tray of console two reveal two more screws.
step 4: remove all screws that we just revealed (5)
step 5: remove chrome trim piece around shifter. some guy online said he used his finger LOL! that thing is in there tight, so i just used a flat head screwdriver and worked my way around. pop up one section at a time just slightly until your all the way around.
step 6: remove console trim around shifter and cupholders. they are just clipped in so just yank it outta there.
this is what it should look like
step 7: remove the trim around the radio. it all comes out theres just a bunch of clips. i found the best way to get leverage was to grab it near the bottom.
Now this piece has several connectors that need to be disconnected before you remove it so i left it like this until they were all done.
Step 8: remove the fully disconnected trim piece to reveal 4 screws that hold in the radio. 7mm i believe and this is what it looks like.
step9: disconnect the three connections on the back of the radio and pull it out.
step 10: now the PAC CHR3 is just for NON amplified stock systems. there is one for the alpines and what nots i think its CHY3 or something like that.
Plug the harness from the truck into the plug from the CHR3 and than the other end of the CHR3 goes into the radio. This unit provides two sets of preamp outputs and a REM cable.
thats it! re-install is just the opposite of what we just went through. i would have detailed the amp wiring kit process but im a little ashamed of what i used for a hole through the fire wall and a ground, but it works! my amp is underneath the drivers seat but its a little big and sticks out the back so i might have to find another amp. Plus this box was said to fit QCs from 02-08 and i was told it fit through 12 but the seats wont fold down with the subs back there. I plan on getting some spacers and hopefully that will work . if not than i need a new box!
quietpeen
2021 TRX
Hellcat
nice write up man. That chr 3 is really tempting since i wouldn't have to tap into the wires like you have to with a loc. Does it also have an integrated remote wire to turn on the amp?
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
cool!
Butch, don't you have the Alpine setup in yours?
DisturbedGator
DisturbedGator
yup it sure does have the remote turn on wire! seamless way to add some bass to your stock setup imo. way better than a line out converter to me. is there a fox box for the 09+ quad cabs yet?
LB3711
Trumbull, CT
3.6L V6
damn I should have gotten that instead of the line out converter. Yes theres a fox box. I have it.
DisturbedGator
DisturbedGator
do you have a link for that box?
DisturbedGator
DisturbedGator
dang i wish he had a sealed one for some tens.
Captain McGillycutty
Maumelle, Arkansas
2011 Power Wagon
I did this a while back and its by far the best mod. Clean, plug and play, and works great. My old 3rd gen fox box even fit under my 4th gen seats so it worked perfect. I like mygig to much to get rid of it so this was the best option.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
nice write up, man that CVR is old school!!!
LB3711
Trumbull, CT
3.6L V6
nope, and i'm still shocked at how good it sounds..lol
I bet better. I forgot to hear it. Full range to all the 6x9s are way better. I wish I can do that to mine
shawnsetia
for the 4th gen ram with the alpine touch screen head unit you need to order the pac chy23 and that gives you remote out and rca outs for your amplifiers and it plugs between the stock wiring harness and the stock head unit.. i picked 1 up of ebay for like $120 they usually run for like $160 and then you dont have to splice and wires it would cost over 100 for get a line out installed professionally anyways so this is something you can do yourself
shawnsetia
my question is can somone help direct me or just inform me on how to run my rca wires from my pac module so behind the factory alpine unit to my amp under/behind the back seats... do i have to pull the carpet/panels and center console.. or do i have to drill holes in the carper and for the 4 guage going to my battery do i drill a hole in that plastic cover near the firewall its for the clutch pedal right? has anyone done this?
WhiteExpress
Midland, TX
I will have to refrain from ordering this up right now. It seems like the perfect option for me. How you like that Kicker Amp? I haven't had a system in quite a while, feel very 'out of the loop'. I love my Comp VR 10s.
TNhemi12
I've done alot of research and everyone I've seen has drilled a whole through the plastic cover on the firewall that you are referring to for the power wire to run through and put a grommet in there. As for running your RCAs, I would guess it's just your preference. I'm going to try and run under the carpet, plan on doing this weekend.
