Dodge POS
kust3mz
2004 dodge ram 1500
3.7 5 speed
I have a 04 dodge ram 1500 3.7 5 speed 2wd truck with 30,000 miles on it, I changed the brakes and had the rotors resurfaced, Witch all looked like new anyways, reason for changing them is when i apply my brakes it squeals when i press them harder it stops, I put new Akebono Ultra Premium Ceramic Pads 79.99$ at advanced auto, And IT STILL F*CKING SQUEALS what can I do to stop that **** it's so annoying!!!! Please help.
kust3mz
kust3mz
2004 dodge ram 1500
3.7 5 speed
Akebono Pro-ACT Ultra-Premium brake pads utilize OE-validated, application-specific friction formulations. This helps ensure that Pro-ACT Ultra-Premium brake pads will provide a reliable braking experience. With the Akebono Pro-ACT Ultra-Premium product line, all customers will receive OE-quality replacements for many popular domestic and Japanese vehicles.
Product Features:
Clean Wheels
Ultra-quiet
No Break-in Needed
Extremely Rotor Friendly
Vehicle-Optimized Ceramic Formulas
Ultimate upgrade for OE semi-metallic and low metallic brake pads
LB3711
Trumbull, CT
3.6L V6
i buy semi-metallic and never had noise problems. Only when I tried to go to something better "performance" pad. plus ceramic will wear the rotors faster. I rather spend $50 on a set of pads than $50 each for rotors
kust3mz
kust3mz
2004 dodge ram 1500
3.7 5 speed
I had RAYBESTOS PROFESSIONAL GRADE SEMI-METALLIC PADS nothing but brake dust and noise, So I switched to a better brand, No matter what I do this little squeal will not leave
kust3mz
kust3mz
2004 dodge ram 1500
3.7 5 speed
There is grease for the back of the pads to stop it from squealing
Yes it came with the pads I applied to the back of them still no help!!
bigtigga84
dela....where?
I have wagner thermo quiets on the front. Haven't changed the rears since I got my truck, but I asked the same thing about a week ago and was told about the grease
kust3mz
kust3mz
2004 dodge ram 1500
3.7 5 speed
I also cleaned the hell out of the rotors after I had them resurfaced still no help
kust3mz
kust3mz
2004 dodge ram 1500
3.7 5 speed
I applied it on the back of the pads still no help
LB3711
Trumbull, CT
3.6L V6
i never used the grease. Only place i used grease is on the guide pins to make sure they move and also make sure the pads float free wher they sit. I had pads rust in place and seize on my ranger I had.
bigtigga84
dela....where?
I haven't messed with it yet, just relaying what I was told. The wagner on the front don't make any noise at all. I will probably end up changing the rears soon just because I want better pads
kust3mz
kust3mz
2004 dodge ram 1500
3.7 5 speed
I don't no what to do with em
kust3mz
kust3mz
2004 dodge ram 1500
3.7 5 speed
Sounds like thats what i have to do lol
kust3mz
kust3mz
2004 dodge ram 1500
3.7 5 speed
Semi-metallic pads
adamwilkes14
Might try getting some brake pad shims...sometimes they dont get reused when someone does the brakes...
ramhunter9
P-Star Jeep Wrangler
You need new rotors , the previous owner was a d-bag . at 30k you should have not had to turn your rotors . = they are fukked up beyond repair .
adamwilkes14
That all depends...most brake shops will turn them to "true" them reguardless of mileage...if they checked them for runout and found even a small bit of runout they would have turned them.
BUT...they should have turned a special surface deal on them too, that helps break in the pads...and to be totally honest, ceramic pads can be noisier than some pads, its just how they are.
adamwilkes14
Another deal, you know you CANNOT get rotors turned in my area? All the shops stopped doing it...Advance use to do it for $15 a rotor, but they stopped. The only ones that do it is places like Midas, and they have to be the one doing the whole brake job.
joshhhh
