Does the J&L oil separator catch can work w/ 5.7s that have the G/T package (factory CAI) ?
atom631
New York
cant seem to find a definitive answer on this. emailed the company, but thought Id check here to if anyone with a G/T package is running it? and if so, anything addtional needed to be done with the install?
Can't see why it wouldn't,you still have a PCV on your 5.7 in the G/T
gt8684
Louisiana
I have the J&L on my 22 G/T... It works, but I did have to modify the rear hose going towards the PCV valve, the 48V cable support bracket that goes from the driver to the passenger side was in the way. I changed the hose on mine, picked up a preformed one from Summit, basically an L shaped one that I cut to fit, I don't recall the part number, if you are interested I can try to go dig it up. You may be able to change the mounting bracket/location as well, not sure.
TMFMK
