Ram Wagon
- Joined
- May 30, 2018
- Posts
- 171
- Reaction score
- 225
- Location
- SW Washington
- Ram Year
- 2018
- Engine
- Hemi 6.4
My son is deployed overseas and i am keeping his car for him. He asked me to get some maintenance done and this is what i've found out. it's a 2014 Ford Fusion
14 recalls..........I think our power wagons are doing pretty good overall.
NHTSA Vehicle Safety Recalls
- Recall Number
14V597000
Recall Date
09/26/2014
Component
SEAT BELTS
Summary
Ford Motor Company (Ford) is recalling certain model year 2013-2014 Ford C-Max vehicles manufactured January 19, 2012, to November 21, 2013; Ford Fusion vehicles manufactured February 3, 2012, to August 24, 2013; Ford Escape vehicles manufactured October 5, 2011, to November 1, 2013; and Lincoln MKZ vehicles manufactured April 25, 2012, to September 30, 2013. The coating on portions of the Restraint Control Module (RCM) may crack, and when exposed to humidity, circuits on the printed circuit board may short.
Consequence
The short circuits could cause the frontal air bags, side curtain air bags and the seat belt pretensioners to not function as intended when needed, increasing the risk of occupant injury in the event of a crash.
- Recall Number
18V167000
Recall Date
03/12/2018
Component
STEERING:WHEEL AND HANDLE BAR
Summary
Ford Motor Company (Ford) is recalling certain 2014-2018 Lincoln MKZ and Ford Fusion vehicles. The steering wheel retaining bolt may loosen allowing the steering wheel to detach while driving.
Consequence
A steering wheel detachment can cause a loss of steering control, increasing the risk of a crash.
- Recall Number
18V471000
Recall Date
07/16/2018
Component
POWER TRAIN:AUTOMATIC TRANSMISSION:LEVER AND LINKAGE:FLOOR SHIFT
Summary
Ford Motor Company (Ford) is recalling certain 2013-2014 Ford Escape, and 2013-2016 Ford Fusion vehicles, equipped with six-speed automatic transmissions. The bushing that attaches the transmission shifter cable to the transmission may degrade over time and cause the bushing to detach from the transmission. The condition could allow the driver to move the shift lever to Park and remove the ignition key, while the transmission may not be in Park, with no warning message or audible chime.
Consequence
If the vehicle is exited without the transmission being in Park and without the parking brake being applied, the vehicle may unexpectedly move, increasing the risk of a crash.
- Recall Number
15V250000
Recall Date
04/28/2015
Component
STEERING:ELECTRIC POWER ASSIST SYSTEM
Summary
Ford Motor Company (Ford) is recalling certain model year 2013-2015 Ford Fusion and Lincoln MKZ vehicles manufactured February 3, 2012, to March 20, 2015, and 2015 Ford Edge vehicles manufactured February 26, 2015, to February 28, 2015, and originally sold, or currently registered in, Connecticut, Delaware, Illinois, Indiana, Iowa, Maine, Maryland, Massachusetts, Michigan, Minnesota, Missouri, New Hampshire, New Jersey, New York, Ohio, Pennsylvania, Rhode Island, Vermont, West Virginia, Wisconsin and the District of Columbia. In the affected vehicles, snow or water containing road salt or other contaminants may corrode the electric power steering gear motor attachment bolts.
Consequence
If the bolts corrode, the steering gear motor may detach from the gear housing resulting in a loss of power steering assist. Loss of power steering assist would require a higher steering effort, especially at lower speeds, which may increase the risk of a crash.
- Recall Number
14V736000
Recall Date
11/18/2014
Component
POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM)
Summary
Ford Motor Company (Ford) is recalling certain model year 2014-2015 Ford Fusion vehicles manufactured July 27, 2013, to October 31, 2014, 2015 Ford Fusion Hybrid vehicles manufactured February 24, 2014, to October 31, 2014, and 2015 Ford Fusion Energi vehicles manufactured July 14, 2014, to October 31, 2014. In the affected vehicles, the key may be able to be removed even while the transmission is not in Park. Thus, these vehicles fail to comply with the requirements of Federal Motor Vehicle Safety Standard (FMVSS) No. 114, "Theft Protection and Rollaway Prevention."
Consequence
If the key can be removed despite that the transmission is not in Park, a driver may think the vehicle is safety parked, when it is not, increasing the risk of a vehicle rollaway that could cause the vehicle to strike and injure the driver, other vehicle occupants, or bystanders.
- Recall Number
14V164000
Recall Date
04/02/2014
Component
SEATS:FRONT ASSEMBLY:RECLINER
Summary
Ford Motor Company (Ford) is recalling certain model year 2013-2014 Ford Fusion and Lincoln MKZ vehicles manufactured August 15, 2012, through September 10, 2013, 2013-2014 Ford Escape vehicles manufactured June 5, 2012, through August 12, 2013, and 2013-2014 Ford C-Max vehicles manufactured from July 23, 2012, through May 28, 2013. The driver and passenger seatback assemblies may have been produced with sub-standard weld joints used to attach the seat back recliner mechanism to the seat frame. The affected seat backs may have insufficient strength to meet the requirements of Federal Motor Vehicle Safety Standard (FMVSS) number 207, "Seating Systems."
Consequence
The back of the subject seats may become loose or lean while driving and potentially increase the risk of injury in certain crashes.
- Recall Number
16V875000
Recall Date
12/05/2016
Component
SEAT BELTS:FRONT
Summary
Ford Motor Company (Ford) is recalling certain model year 2013-2016 Ford Fusion vehicles manufactured November 2, 2012, to July 31, 2014, and 2013-2015 Lincoln MKZ vehicles manufactured November 14, 2012, to July 31, 2014. In the event of a crash, heat from the deployment of a seat belt pretensioner may cause a front seat belt anchor cable to fail.
Consequence
If the driver or front passenger seatbelt cables cannot properly restrain the front seat occupants, they would be at an increased risk of injury.
- Recall Number
15V246000
Recall Date
04/24/2015
Component
LATCHES/LOCKS/LINKAGESOORS:LATCH
Summary
Ford Motor Company (Ford) notified the agency on April 23, 2015, that they are recalling certain model year 2013-2014 Ford Fusion and Lincoln MKZ vehicles manufactured July 1, 2012, to May 31, 2013, and 2012-2014 Fiesta vehicles manufactured February 1, 2012, to May 31, 2013. On April 30, 2015, Ford expanded the recall to cover an additional 119,567 vehicles, including certain model year 2011 Ford Fiestas manufactured from November 11, 2009, to May 31, 2013 and certain model year 2013 Ford Fusion and Lincoln MKZ vehicles manufactured from February 1, 2012, to June 30, 2012. A component within the door latches may break making the doors difficult to latch and/or leading the driver or a passenger to believe a door is securely closed when, in fact, it is not.
Consequence
A door that is not securely latched could open while the vehicle is in motion, increasing the risk of injury to a vehicle occupant.
- Recall Number
17V210000
Recall Date
03/27/2017
Component
Summary
Ford Motor Company (Ford) is recalling certain 2014 Ford Fiesta, 2013-2014 Ford Fusion and 2013-2014 Lincoln MKZ vehicles. A component within the door latches may break making the doors difficult to latch and/or leading the driver or a passenger to believe a door is securely closed when, in fact, it is not.
Consequence
- Recall Number
18V169000
Recall Date
03/12/2018
Component
POWER TRAIN:MANUAL TRANSMISSION
Summary
Ford Motor Company (Ford) is recalling certain 2013-2014 Ford Fusion vehicles equipped with a 1.6L GTDI engine and 6-speed manual transmission and 2015-2016 Ford Focus vehicles equipped with a 1.0L GTDI engine and 6-speed manual transmission. Also included are four 2017 Ford Focus vehicles that had clutch replacements with potentially affected parts. The clutch may fracture, resulting in damage to the transmission assembly and possibly a transmission fluid leak.
Consequence
A transmission fluid leak in the presence of an ignition source such as hot engine or exhaust components can increase the risk of a fire.
- Recall Number
17V209000
Recall Date
03/27/2017
Component
ENGINE AND ENGINE COOLING:ENGINE
Summary
Ford Motor Company (Ford) is recalling certain 2014 Escape, 2014-2015 Fiesta ST, 2013-2014 Fusion and 2013-2015 Transit Connect vehicles equipped with 1.6L GTDI engines. If the vehicle is started and driven with an insufficient level of coolant within the engine cooling system, the engine cylinder head may overheat, crack and leak oil.
Consequence
If the cylinder head cracks and leaks oil, the oil may contact a hot engine or exhaust component, increasing the risk of a fire.
