Don't know what to do, please help
jared.hammel
Knob Noster, MO
Magnum 5.9L
My 99 RAM 1500 5.9 Magnum has Champion 3436 platinum plugs in it. I ordered new plugs, same part number and they are much smaller. No shop had the plugs I need! Someone please help!
sbarron
Wasilla, Alaska
much smaller as in length or the threads are smaller diameter? That IS the correct plug for your truck.
J
jared.hammel
Knob Noster, MO
Magnum 5.9L
The plugs that I ordered from Summit Racing are smaller and have JN stamped on them. The ones in the truck are a larger diameter and AI (or A1) Stamped on them.
sbarron
Wasilla, Alaska
hmmm.. Original heads/motor? Guess I'll wait for pictures.
J
jared.hammel
Knob Noster, MO
Magnum 5.9L
To be honest I don't know. :/ Just got the truck a few weeks ago. Guess I should have asked.
sbarron
Wasilla, Alaska
hard to see from those pictures, but is it possible that the old plug has a helicoil on it or some kind of threaded insert that came out when you unscrewed the plug? Do ALL your old plugs have the same larger thread?
J
jared.hammel
Knob Noster, MO
Magnum 5.9L
You know what, I haven't pulled any others out... I'm gonna go do that.
J
jared.hammel
Knob Noster, MO
Magnum 5.9L
So I pulled a different plug and it was smaller than the first plug i pulled and the threads were different. It was also the same as the ones from summit racing. So what do I do about the thing the first plug pulled out?
sbarron
Wasilla, Alaska
You're kinda in a bind...
Options -
1. Replace head. Ugh.
2. Put new helicoil in offending cylinder, auto parts store should be able to help you out. Take the old plug with the helicoil, a new plug with you...
You really shouldn't reuse helicoils. The bad thing about having the head on the truck is that you really need to run a tap down the plug hole to make sure the threads are good to accept the new helicoil. With the head on the engine, you run a slight rick of chasing debris into the cylinder, though you could blow and/or vacuum it out. The other part of this is it's something you'll need to be wary of every time you change the plugs.
edit: and agree, the copper plugs will save you some dough and work just fine.
J
jared.hammel
Knob Noster, MO
Magnum 5.9L
Options -
That's good to know. Thank you for all the help! Oh, and on summit racing, the copper/platinum are $1.97 each...
J
jared.hammel
Knob Noster, MO
Magnum 5.9L
lol... forgot you didn't have 16 of them...
So on sort of an unrelated side note, what should I do in terms of a muffler? I don't want it to be insanely loud, but I also don't want it to sound stock. I got a replacement cat since mine is clogged and want to do them both at the same time.
Lethalweapon100
NY
V8 5.9 Magnum
I have a flowmaster super 44 on my truck with a side dump before the wheel. Sounds awesome. Not too loud, but loud enough to sound good.
Sent from my SM-G920P using Tapatalk
