Another Power Steering Question
chuth10
Minnesota
Hey All, I've done some research on here about ERP issues. I'm pretty confident I will need to replace mine on my 2017 Ram 1500. Before I do, I have a few questions about this.
1) On a scale of 1 to 10, what is the difficulty of replacing this yourself? I consider myself fairly mechanical, replacing my brakes, oil changes, starter, spark plugs, other odds and ends.
2) Does this need any type of programming following the install? Obviously know I will need alignment, but I don't have a programming tool.
3) I see there is a Mopar part available right now on Rock Auto with the part number being 68256617AA. This is a different part number than what the dealership gave me. Will this still fit?
Any other advice you have before I tackle this project will be great!
Thanks,
Chris
Ken226
Washington State
It's EPS.
About a 3. It would be a 2, but it's kinda heavy. It's a 1 if you have help, a lift and the right tools.
Not if you use a new, OEM Mopar unit.
The one from RockAuto is OEM Mopar, and will (should} work but 68628858AA is the latest revision.
There's about a million different part#s. Mopar is nuts with their part numbering system.
Don't use aftermarket. 2 aftermarket units, a warranty fight, then an OEM one anyway, are NOT cheaper than just buying one OEM unit from the start.
Thanks,
Chris
Your welcome.
C
chuth10
Minnesota
It's EPS.
Your welcome.
I really appreciate that information. One last question/confirmation... Does your link you gave me for the rack and pinion come with the outer tie rods? I will be changing these as well. Ive seen where in some instances in videos, it comes with it. Just trying to avoid a duplicate order.
Thanks again!
Ken226
Washington State
Thanks again!
That's where I ordered mine and it did come with them.
However, Its been awhile and of course, I'm not in a position to guarantee what they may or may not send.
RamDiver
Marlborough, Ontario Canada
2021 DS
Thanks again!
You could ask Benny for a quote, and he will be able to answer all your questions.
Send a PM to @AllMoparParts.com and include your VIN.
