Door accent lighting
sweenmystr
2018 3500 laramie DRW
Hey guys
My Laramie came with blue accent lighting in the doors. I was wondering if its possible to change the colour.
Thanks
kad
Hudson Valley, NY
5.7L HEMI
Not without some major work. You'd need to rebuild the units inside the door by hand with a different color LED and matching resistors. They are sealed units and the components are surface mounted. Unless you're very good at doing hot air type solder rework, it's probably not going to be possible.
-K
P.S. You might be able to get a somewhat different color with a coating. i.e. apply a red coating to the unit and get purple light, a yellow coating and get green, etc. I've used the Tamiya transparent model paints to tint LEDs before.
-K
sweenmystr
sweenmystr
Thanks Kad
That's quite the task, so I think I'll pass but thanks for the insight. Was hoping it would be simple as switching other bulbs but obviously not.
Cheers
