E brake
waffleman10
Connecticut
I think my E Brake is stuck. When i turn the truck on the Brake light flashes indicating the E brake is on. When i pull the release and the e brake seems to be releasing but the light keeps blinking. When i drive you can tell that the e brake is on because there is alot of resistance. I checked to see if the cable was jammed but it wasn't. I checked behind the rotor on both back wheels and it looks like the E brake is released. Any thoughts? Thanks
JPT
NY
2015 Big Horn
That might be the light for low brake fluid. Have you checked your reservoir?
Hemiram
PA
Mine did exactly the same thing.
Found out that the parking brake had broken at the rear wheel. it was not releasing. Piece finally broke off and wedged.
Had to pull axle to repair it so I did rear end fluid change
JPT
NY
2015 Big Horn
You had to pull the axle shaft in order to get the brakes out? I just did my rear brakes (including new parking shoes and hardware) without pulling the shafts out. It was some extra work, but possible.
Hemiram
PA
I guess 'had' wasn't best choice of words. Needed to replace broken parking brake. It did make job easier.
waffleman10
waffleman10
Connecticut
that is what happened to mine, the shoes rusted and were stuck, and needed to run a new cable.
joshhhh
