E-Fan
SMKN
Waynesville, NC
So how many of you are running electric fans for cooling? Which fan are you running and how did you configure it?
I am running a Taurus fan with a controller on low speed and a bypass switch for the high speed.
BEAR
Redneck County, USA
2005 Ram 1500 HEMI 4x4
I'm running the Flex-a-lite BM Extreme 180 E-Fan. I also have a JP 180* T-Stat so my fan is set to come on about the same time as the Stat opens.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
I bought mine from Moe's (flexolite) I have the temp set for 195. This setup only has my fan running when I standing in traffic. Actually the fan very seldom comes on. Highly recommend.
Forgot: I also am using a 180 stat. I think the thermostat is also a good mod. Good luck..
ramhunter9
P-Star Jeep Wrangler
i still am on the fence on this mod , trying to find a good kit
Taurus e-fan for the last couple years with a flex a lite variable speed adjustable controller. I like the variable speed controller bc it allows me some adjustability of when the fan goes on as seasons and temps change.
S
SMKN
Waynesville, NC
Hey Teach it would be nice to have a DIY for this, you wouldn't have one by any chance would ya?
I have the one I did for DF a while ago. You want it to add to the DIY?
RubberFrog
I ran both a markviii fan and a viper fan. Both were solid and reliable. In fact, I have an adjustable thermostat that I am going to put in the classifieds tonight.
nim81
Fredericktown, MO
5.7L
im running a taurus fan with adj. temp controller on high speed. had it on low but every time i went off road the lil ******* would start heat up, though it has been pretty hot here lately.. its set about 180*F with my t-stat. i have soo much more room in my engine bay compared to my stock setup. lovin it!
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Thnk he is going for a stock appaerance under the hood. I have thought about an efan alot because it makes it easier to access the front of the motor but my only worry is that if it breaks and im out in BFE and dont know its no longer working I will overheat.
nim81
Fredericktown, MO
5.7L
if you have a tool box in your bed you could keep your stock fan in there for backup or steal your condenser fan and fab it up to the radiator real quick for the limp back to civilization... of course im assuming everyone carrys tools and stuff with them all the time as i do
BEAR
Redneck County, USA
thats what I do...
I have kept the stock fan in my truck since the day I put the e-fan in just in case.
AParrette
St Augustine, FL
1997 Pontiac Grand Prix
3.8L SUPERCHARGED
well if your gonna keep your fan in there you should keep a cheap spanner wrench as well in your tool box
electricalservice
