ECM Connector
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Anyone have a used ECM connector (hopefully with wiring pigtail still attached) laying around you don't want?
Building a bench test / programming rig for the the '16 ECU's
Thanx in advance
  • Visio-PCM Bench Test schematic.pdf
RamDiver
Marlborough, Ontario Canada
2021 DS
Thanx in advance
You might have better luck with a wrecking yard.
That's a great idea. Have you found any design ideas?
04fxdwgi
04fxdwgi
2016 1500 Sport
The design / wiring is in the PDF. It has the twin power supplies, the ECM connector and an OBD2 port for the programmer. Easy peasy.
Checked all the bone yards around here. Either don't have any compatible vehicles or they want huge dollars for the whole harness.
RamDiver
2021 DS
Thanks.
My eyes & brain must have filtered out the attachment when I was using the phone earlier. :cool:
Ken226
Washington State
Thanx in advance
The Continental gpec2 and gpec2a use the same physical connectors, but slightly different pinouts depending on which transmission, year, etc.
Gpec2 was used from 2013 to 2014, then I think the locked 2015+ was rebadged the gpec2a, so your bench testing connectors should cover 2013 up to about 2021'ish.
So, you should be good with something like this:
It doesn't show in the pic, but the description mentions that it has the pins and a short length of the wiring.
joshhhh
