I think the Tow/Haul mode switched on will also disable eco mode.
I think it may also stops the transmission from going into the higher gears.I think you're right. Just wondering though, does tow/haul change the parameters on the transmission? I haven't tried it on my 1500, but I know it changed most everything on my previous F-150.
It can be temporarily disabled using the gear limit switches, as described above by @Wanted33 . Tow/haul mode works too (on 5th gens), but it changes the shift parameters of the transmission, and it will affect fuel economy.Can the ECO Mode be be disabled or turned off permanently on a 2021 1500 ram w/ 5.7 engine.
Actually, it's worse than that...you have to disable it every time you shift into D.Yes sir, but you'll have to do it everytime you start the engine.
Yes, move to Nebraska and the wind will make sure it never comes on. It will also help keep the tranny from shifting into 8th gear, so you get a cool 10 to 12 mpg!!Can the ECO Mode be be disabled or turned off permanently on a 2021 1500 ram w/ 5.7 engine.
