Electrical Gremlin is here.. help!
Canada
Had no brake lights, turns, or hazards at all. Turned out it was my aftermarket tails. ( far right ones )
Put back in my stock ones, changed the fuses that was blown and changed multi function switch, those work fine again except four ways ( hazards )
Hazard lights DO NOT work, but turns, brakes, running lights, reverse lights ALL work.
Checked fuses ( nothing is blown )
Checked relays ( nothing is blown )
Checked flashers ( swapped them both around and tried , still works.
Changed the multi function switch to see if that was it, still doesn't work.
When I have the four way button pushed all the way down, everything works ( minus the four ways ).
When it's up all the way, nothing works except my running lights.
Any ideas?
I am gonna check the hazard relay under the hood tomorrow to see if it has power going to it, and that could be the solution.
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
I recently purchased a 2001 cummins wrecker with this issue and a few other. Change the relay in the driver dash fuse box it fixed everything for me once I had the wiring corrected for the lights.
My engine bay fuse box is also loose, so try messing with your flasher 30 amp in there
joshhhh
