Electrical Gremlins - 2021 Ram 1500
popeyegui
Canada
I've encountered more than my fair share of gremlins this winter:
1. If the outside temperature is <-18C, my low washer fluid alert is illuminated. Fluid is not frozen or gelled and it sprays fine. Check the connector at the reservoir and no corrosion. Works fine if >-15C
2. Sirius XM channels I have programmed to skip will randomly reappear and channels I have allowed will be gone. This is really annoying. Presets don't change, however.
3. If the alternator belt gets wet & slips, the truck goes into power saver mode and doesn't automatically reset once alternotor begins charging again.
Has anyone else noticed these? Any fixes?
Brandon-w
Yukon
2015 Ram 1500
What kind of water are you getting into to make the alternator slip? I've never had that issue ever. Wonder if you have a weak tensioner. The first two I cant help you with. Maybe a factory reset in the head unit? The washer fluid don't make a lick of sense especially only at - 18 that's like all the time here.
