Electronic Assisted Power Steering Failure
eprovenzano
Wellsburg WV
2015 Ram 1500
At 35,500 mile the power steering started to act up. The steering wheel was very stiff for the 1st 15 degrees of a turn, then loosen up to normal, and then stiff again as you continued to turn the wheel. When you turned the wheel, it would not return. So as you went around a bend, you'd better be prepared to straighten the wheel... As it started to happen it would come and go, but as it warmed up it would be normal. that was up until now as its acting up all the time now.
I first checked for a recall... there was a similar issue with a few steering racks, but my vin was not part of the recall.
Mileage continues to climb... now up to 36,500. Called the warranty dept., was told they needed an authorization work order from a dealer before they could get involved.
Got an appointment at the local dealer, took it in and was told sorry we over booked and you bring it in next week... mileage now up to almost 37,000... Took it back in today (now mileage over 37,200.) and asked if I could get a ride to my office as it's just down the street. The warranty manager offered... I mentioned we should take my truck so he could see first hand the issue... I explain to him I've brought the truck there to have the steering looked at... he pulls out onto the road and was like HOLY CRAP what's wrong with the steering... I again explain I believe it's the Electronic Assisted Power Steering failing. He was shocked... I also threw in that I believe it's a safety hazard... that I can't allow anyone but me to drive the truck ...
Just received a call from the dealer... yes it's the Electronic Assisted Power Steering Rack that needs replaced... was told even though you are over your warranty mileage, we're going to complete the repairs under the warranty...
I priced the parts from Dodge... minimum $1,500 plus labor, so at least $2,000.... to replace the steering rack.
Thanks God they honored the warranty or it could have gotten ugly...
An appointment has been scheduled to have the steering pack replaced, with a front end alignment. I'll report back after the repair.
huntergreen
Marine Corps Navy Badge
Sounds like you have a good dealer.
E
eprovenzano
Wellsburg WV
2015 Ram 1500
It's scheduled to go under the knife tomorrow. One fuill day to replace the rack, and realign the front end. I'll report back as to the results.
E
eprovenzano
Wellsburg WV
2015 Ram 1500
From what I've read they "believe" it's the internal electronic circuit board that's failed. I dropped off the truck this morning. when I pick it up tonight, I'll ask if they know what the culprit is.
When it started to happen, the first thing I did was look for a recall... I found the same recall listed above. i called and was told my VIN was not part of the recall, less then 500 trucks were effected.
Fitz-0518
Veteran 66-68
Central California
2018 2500. 2018 1500
Love how you handled. Stay loyal to that dealer. Glad to hear the outcome.
6.7CumminsDrvr
The Dude abides………
Georgia
Glad they got you taken care of........had mine replaced twice. Mine wasn’t doing what yours was doing but it was replaced and after the instal the new one was doing the same thing as my original......fun couple of days at the dealer!
E
eprovenzano
Wellsburg WV
2015 Ram 1500
I'm back to report that I have good news and bad news...
New steering rack installed, including alignment... :banana-mario: Bad news, its still acting up... not quite as bad, but still not right. :banghead: Next they are going to replace the steering stem thinking a universal has seized. Almost, but yet so far... :Big Laugh:
At first they tried to blame the lift... I shut that BS down pretty quick.. I've put over 15k miles on it with the lift without issue. The lift keeps the steering is in the factory location, with the factory geometry. The steering rack is untouched with the lift. The replacement knuckles keep the tie-rods in the factory position. After I gave the Service Manager the facts, he agreed it's not the lift... the only thing left is the steering stem.
E
eprovenzano
Wellsburg WV
2015 Ram 1500
An appointment for Friday has been made to have the intermediate steering shaft replaced. I will also be discussing the tire alignment they did.. now the steering wheel is not straight, and the truck pulls to the right... yes I will make sure I'm satisfied before I sign off on the repairs...
E
eprovenzano
Wellsburg WV
2015 Ram 1500
GOOD NEWS!!! Its been fixed. The steering stem had a bad universal joint. It was so bad they even saved it to show me... The alignment has been corrected and the steering wheel in in the center... All fixed under warranty. I am a happy satisfied customer.
TerraNewf
NL, Canada
Glad to hear of a good outcome, enjoy that ride
KAKA
