Engine swap
mudman36
US
Ok im sure its been asked but im new to dodges and new to this forum so apologize first.. Second my question is i have a 99 dodge ram 1500 with 5.9 and 4x4 and an 02 ram 1500 with the 4.7 and 4x4 which the 4.7 is in bad shape so what would it tale to swap the 5.9 into my 02. Besides the computer would it be a direct bolt in or are we talking frame work to relocate mounts. Thanks
Sent from my LM-Q720 using Tapatalk
Dan98
Your gonna want the transmission from the 5.9 46re motor mounts and wiring harness and ecu. Good luck
Sent from my SM-J260A using Tapatalk
M
mudman36
US
I have Both the 99 5.9 running truck but bad frame and a late 02 dodge rame with the 4.7 so donor vehichles isnt a problem just wobdering if i need to cut the old mount brackets out and relocate or if there thw same. My 02 is about 40 miles away havent had a chance to go look at it yet
Dan98
I would not think you should cut anything or even need to. Was the 5.9 offered in that year truck if so than it should go in it. You have both vehicles in front of u look and measure you can tell
Dan98
Ronsterritory
