JJEH
- Joined
- Dec 11, 2012
- Posts
- 540
- Reaction score
- 435
- Location
- Central Texas
- Ram Year
- 2018
- Engine
- 5.7 HEMI
The morons that be set it up to a default upon restarting the car, thus, one must turn it off every time.Quick question, doesn't almost every car equipped with this have a button to turn the feature off? Then it won't start/stop.
It's fair you say it is no issue, considering you, yourself, haven't had one yet. But there are many others (including myself) that find it annoying and just pointless. I think everyone should stand a chance when it comes to working on their own vehicles. Yes of course there are things that you just can't avoid taking it to a mechanic simply because you lack the necessary tools. And who wants to spend 400$ at AutoZone for a tool you might use twice if you're lucky. The less moving parts, the less complex, the less required maintenance, the better. And I personally think that the EPA's removal of such complex & unnecessary parts is beneficial for the folks who enjoy working on their own vehicle and saving those multiple 100 dollar plus labor fees. Also I'm glad you brought up the fact that some states will still require it. That is so true. But the end of the fed requirement is a great step.I've had it in several vehicles and it isn't an issue.
I've never had any of the issues listed - if the second that it takes to start is causing people to think that you aren't paying attention or more likely looking a your phone, chances are that is what is happening.
Annoying, sometimes but usually pretty seamless. If you want the engine to start earlier, just lift ever so slightly on the brake pedal and like magic the engine starts - and you don't even move.
It shouldn't be a requirement, but you can bet it will be a requirement in some states - so ending the fed requirement is less of a big deal than it seems.
So annoyingThe morons that be set it up to a default upon restarting the car, thus, one must turn it off every time.
I didn't say it wouldn't be annoying to some people. I've found that some people can get annoyed at most anything haha.It's fair you say it is no issue, considering you, yourself, haven't had one yet. But there are many others (including myself) that find it annoying and just pointless. I think everyone should stand a chance when it comes to working on their own vehicles. Yes of course there are things that you just can't avoid taking it to a mechanic simply because you lack the necessary tools. And who wants to spend 400$ at AutoZone for a tool you might use twice if you're lucky. The less moving parts, the less complex, the less required maintenance, the better. And I personally think that the EPA's removal of such complex & unnecessary parts is beneficial for the folks who enjoy working on their own vehicle and saving those multiple 100 dollar plus labor fees. Also I'm glad you brought up the fact that some states will still require it. That is so true. But the end of the fed requirement is a great step.
Many models have a separate battery for stop/start - basically a small motorcycle battery. The Pacifica stop/start battery lasted 1-1.5 yrs for the ones that I had. Leaving the dead battery in did disable stop/start from functioning![]()
I haven't personally verified it, but multiple users on Jeep forums say Wranglers/Gladiators won't start at all if the stop/start battery is dead even if the 'main' battery is fine. If it worked like you say your Pacifica does then it wouldn't be as big a deal, I think.
I can tell you they work well. I bought this one for our 2022 Jeep Cherokee.My wife's Wrangler has it and it's annoying as hell...
Thinking of buying one of those Auto stop eliminators...
Hard to figure the value of a feature when there's an entire industry developed just to defeat it...Autostop Eliminator - Disable The Auto Start Stop Feature
The Autostop Eliminator is an intelligent tech device for your car, truck or SUV that will safely disable auto start-stop feature and remember your preferencewww.autostopeliminator.com
I did rent a Citroen C5 Diesel with a with a 6-speed when we were in Spain a couple of years back. Driving out of Madrid I pulled up to a stop light, pushed in the clutch and put the car in neutral. When I released the clutch (to save the throw-out bearing) the car shut off. I think I sh$t myself. Pushed in the clutch and the car immediately started. At this point I'm thinking NFW - a manual diesel has stop/start??? Sure enough, there was an option (buried two menu's deep) to turn off the start stop.
I'm not sure on the Jeeps. It wouldn't make any sense but if programmed that way, I could see it happening.I haven't personally verified it, but multiple users on Jeep forums say Wranglers/Gladiators won't start at all if the stop/start battery is dead even if the 'main' battery is fine. If it worked like you say your Pacifica does then it wouldn't be as big a deal, I think.
