Error code 13 -- I THINK
baff
Australia
Cummins 6.7 TD
Hi All,
I THINK my RAM may be getting an error code# 13 with engine light flashes.
13 = MAP sensor or vacuum line may not be working
Is this a big issue ?
The odometer has ----- -> DONE so nothing comes up there.
Is it a "quick" to shop issue ?
baff
baff
Australia
Cummins 6.7 TD
That said, the article I read said the flashes are pre 1998 ?
Do 2011 also do the same flashing codes ?
baff
baff
Australia
Cummins 6.7 TD
Unless its a 12 error code saying the battery had been disconnected... which it had on Thursday for driving lights to be installed ?
baff
baff
Australia
Cummins 6.7 TD
Just rechecked it 3 times.
Started, then off the did 3 key turn thing and did this a few times.
Each time I got an error code 1 - 2. Which seems to mean battery... which makes sense.
I swear I saw a 13 before but will keep an eye on it !
mikep345
