Koolkev1
- Mar 29, 2014
- 9
- 1
- 2001
- 5.9 v8 gas
Need advice...I've got the dreaded p0441 (small evap leak) code. Can't find a leak...smoke test....nothing. Here's what is odd...code is only thrown after cold start. If I let it idle for 3 minutes, the code is sent.
If I clear the code and drive around the code doesn't return and the monitors will slowly come back online (except for the evap monitor and the heated O2 sensor monitor) after drive cycles.
Then after sitting over night the process will repeat....it'll throw the code within 3 minutes of startup.
Ideas????
Thanks
Ideas????
Thanks
