EVIC says low tire pressure
Ramsfan78
St. Peters, Missouri
HEMI 5.7
I am getting a "Low Pressure" indication on my 2010. All tires are at 31 with the exception of the right rear which says it is 28. I put air in the tire and brought it up to 31 but I am still getting the "Low Pressure" warning. Any ideas? Don't know if it could be weather related but its 23 degrees here today and yesterday was 60. I did wash it yesterday.
Sent from my iPhone using Tapatalk 2
TylerB
FL
Could be on because the fact they are at 31psi.
Exhausted
Edmond, OK
Yeah on the door of my truck it says to air to 39psi
31 is to low
Ramsfan78
Ramsfan78
HEMI 5.7
Keep in mind the 31 is a cold reading at 23 degrees. It would probably go up a little after driving for a while I would think. Maybe not to 39 but a little. Either way, they've always been at 31 and I've never got this warning. I'm puzzled. Lol.
TylerB
FL
Have you driven it since adding air to the low tire? It takes 1-2 miles of driving to reset the light.
31psi is still low.
NYCruiser
Yonkers, NY
I think the factory sets the stock TPMS setting at the cold inflation pressure as marked on your door. Try increasing your tire pressure to that and see if the indication goes off.
