exhaust advise
olboyowl
need help deciding which is the best direction to go. Im throwing around the idea of having new mandrel bent tubing welded on after the manifold collectors up to either a duel in duel out magnaflow muffler goin into the remainder of the stock exhaust or an x pipe into 2 mufflers (cherry bomb or thrush mufflers) then into the remainder of the stock exhaust.
dont want a bad drove on the cab but want a good sound. any advice would be appreciated. any idea on a cost of this would be helpful too. thanks
denny
WilCon76
MD
2013 Express 2WD
Cost would be very difficult to guess as local labor rates and shops can vary quite a bit. Either combination may have some drone to it. It is a byproduct of the MDS creating a low frequency harmonic. That is why some companies offer a j pipe to combat this (Mufflex). Why such a complicated approach when a simple replacement muffler will offer roughly equivalent gains in noise and power?
O
olboyowl
i saw a guy on here replaced the pipes between the collectors and the muffler to make it a true duel setup. less restriction then the factory exhaust and the exhaust collector right in front of the muffler.
