Factory subwoofer
Ohio5pt7
Ohio
I currently have the small screen radio which I may upgrade. Couple of questions. 1 will a factory subwoofer work with that radio? 2 is it worth the investment for the subwoofer I found one for 200 shipped that is the under the seat for the crew cab. What else would I need?
Sent from my KYOCERA-E6920 using Tapatalk
Ohio5pt7
Ohio5pt7
Ohio
That may possible I was under the impression it had a built in amp? Not sure?
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
No built in amp. I wouldn't pay more than $120 and I would immediately replace the factory sub in the enclosure with something else. Unless you are trying to maintain a factory fold flat floor I would look at aftermarket options.
Ohio5pt7
Ohio5pt7
Ohio
Thanks for the info
Plankton
Mid West
The sub will need to be powered somehow, and it depends on the head unit and if it has the capability. I haven't watched these in full, but they might help.
Ohio5pt7
Ohio5pt7
Ohio
LeeD
Humble, TX United States
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
