Factory warlock hight
Dustpatey
Labrador
2007 dodge ram 2500hd Sport 5.9L Cummins
5.9L Cummins
Iv just Purchased a second hand 2023 ram warlock and I’m wondering what everyone is getting for factory rake, I’m currently measuring roughly 3 inchs in the difference from front and back , is it possible someone installed non warlock spec front struts?
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
The Ram 1500 Warlock height varies slightly by year and configuration (Classic vs. new generation), but generally falls around 77.5 to 79.2 inches (about 6' 5" to 6' 7"), featuring a 1-inch factory lift and larger tires, providing nearly 10 inches of ground clearance for better off-road capability.
A 2023 Ram 1500 Classic Warlock generally features a 1-inch factory suspension lift in the front, contributing to a more level stance compared to the standard Ram 1500 Classic. While the truck is designed with a more level, off-road-oriented posture, it may still retain a slight rake (lower front than rear) for payload management.
My 2024 classic is about 1.5 inches higher in the rear than the front, put 300 lbs in the back it's almost level.
rockyj69
