brandonbeeb
Hello
Was hoping for some help with some issues I’ve encourtered after switching my stock 2017 1500 interior over to a leather Laramie interior with the 8.4 screen.
My truck has the column shifter and 7speed fan from the factory. I purchased and installed the harness for the heated/cooled seats (front and rear) and the dash plug and all of that works fine. M2 was great, with the radio I had purchased an Amazon harness which I believe is the infotainment style one to use the new buttons with the 8.4 conversion and everything is working fine except for the 7th speed setting on the knob.
The issues I’m currently having is the heated steering wheel and clock spring were also installed and work but after driving for 20 minutes I get the traction light on and it’s saying steering angle sensor. I’ve done the setup in Alfaobd and can clear the light but it keeps coming back, is there a sensor I should be looking at replacing?
The second issue I’m having is when turning the heat on the drivers side footwell isn’t getting much airflow, passenger side is great, wondering if this is an issue with the harness or more likely a blend door/actuator and if there’s a way to test?
Thank you
Thank you
