Few noob questions..
CokeZero
the truck has manual windows. Is it more than its worth to convert them to power?
Also doesnt have the overhead display. Whats needed to add that?
And last, Didn't come with foglights. Is everything there to add them? whats needed?
I'm looking to add some halo headlights with LED's so anyone know the wire colors for the running lights?
Trying to decide between these or the same ones in chrome. They are going on a white truck but it does have the heavy duty black fender flares
JamesRam
AB, Canada
I do know that it is possible to add fog lights, I have looked into it myself for my pickup
JamesRam
AB, Canada
Apparent you can get a kit for around $120 which has everything you need to install them
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
The fog light can be done several ways, I bought OEM fog lights from eBay and used a standard automotive 12vdc relay and toggle switch. Ran a 12vdc fused wire from the battery to the relay, to the lights. Ran an ign on 12vdc wire to the toggle switch, to the relay. With the truck running turn the toggle switch on and off to operate the fogs. Turn the ign off and the fogs don't light. I use mine mostly for daylight running lights.
JamesRam
AB, Canada
What did that cost you after it was all said and done if you done mind me asking?
Redtruck-VA
Virginia
I did this many years ago and I think the OEM lights were around $90 and relay, wire and switch about $20 more. Most of the mods we do don't cost all that much if we do them ourselves. Good luck.
KAKA
