Finally Finished!!!!!!!!! 3" Lift
MvZiC MaN
MvZiC MaN
Port Charlotte Fl
3.9L 295 CI Magnum V6 :(
I didn't mean to make you paranoid, lol. It's just not too common to see bottom mounted spacers. I'm no welder by any means, but I think since those spacers are aluminum and your springs and control arms are steel, it would be a royal PITA to spot weld the aluminum spacers to the steel.
If you want my honest opinion, from the looks of them installed, I just wouldn't trust them the way they sit in the spring bucket in the control arm. The bottom of the spring, the way it sits in the lower control arm in the stock location is isolated. The way those spacers sit in the bucket, it appears the spacer itself isn't even isolated in the lower control arm and the groove in the spacer for the spring to rest in, looks narrower then the spring itself.
If it were my truck, I'd yank them out and just pony up the dough for Daystar spacers. Sure, they're gonna set you back about $131 versus the $30 the ones you have cost, but the piece of mind knowing that you are installing a more common used way of leveling is priceless.
Dave (Ramhunter) could prob put his input in on these and shed some more light on them. Remember, I ain't saying what you have is unsafe or otherwise, I am just stating my opinion.
I understand what your saying.. Thanks!!! im gonna get some shocks and then see how they hold up when i go Wheeling in a few days... I do plan on getting some Daystars Later on down the road but this was to Hopefully Hold me off till then
Renardk764
Magnum 5.2
How are the coil spring spacers holding up? Curious because I'm putting them on my truck this weekend.
Thanks
Ken
MvZiC MaN
MvZiC MaN
Port Charlotte Fl
ive taken my truck out Wheelin Twice since the install and they are Holding Perfectly!!!!!
I was expecting them to pop out or somthing but There are Perfectly fine... (And im not Easy on the truck when im Wheeling thats Enough said about that :roflsquared:)
Hollabakzach23
Lafayette, IN
That is nuts how much lift you got out of the front! Looks good! Let me know how the install on the body lift goes I been going back an forth on getting one. Want to know if the install is pretty easy on the 2nd gens
Hollabakzach23
Lafayette, IN
Oh and as far as shocks I'm running the ranchos on mine and they seem to be holding up well! I went back and forth between them and a set of procomps. And I've heard nothing but good things about them I just got a helluva deal on the ranchos at a local shop.
MvZiC MaN
MvZiC MaN
Port Charlotte Fl
The body lift was actually Pretty easy all you gotta do is take the body mount bolts out and jack the body up with a floor jack and a piece of wood under it and the put the Pucks or lift blocks on top of the Body mounts and drop the body and then Bolt it back up and then the same on the other side!!!!!!
I had it done within 30 or so Minutes
Chop413
Alabama
yeah they are the Ebay ones... and i dont think they are the same.... and yeah it does.... Ill find out Eventually tho
How hard are they to install? I just ordered some for my 2014 2wd. And did you have to get a wheel alignment ?
ChloeBrooks
