First install of Illicit Fab no cut brackets
razor1
razor1
St.Petersburg Fl
looks like on the "no cut" brackets there are 2 separate assemblies to complete a side or 4 plates total per side(correct me if I'm wrong).............I bet getting thicker stock to plasma or waterjet wouldn't be all that difficult to do:happy107:
they fit fine, no issues I see so far.
razor1
razor1
St.Petersburg Fl
original bolt, just drilled a hole a little larger to give some lea way.Mount the plate loosely, I spray a little gray paint through the original hole to give me an idea where to drill. I used a 7/16" bit.
DireRam
Abilene, TX
Any update
Wanted to check in and see how everything was going with the brackets I'm following all the threads as patiently as I can but all the stuff in my garage waiting to be installed is crying.
Goodie1990
