First mod: pulsar, or wait and upgrade others first?
Jho93
Savannah, georgia
2019 classic
So I've looked on here and it's seems most people agree that the first mod you should do performance wise is a tune. I plan on buying a tune when I pass out of warranty at 5yr/60k but right now I have a 2019 ram classic at 23k miles. I will probably put about 15k miles a year on it so I have a little while until I go out of warranty. My question is would it be worth while to buy a pulsar for the remainder of my warranty and then go and buy another kind if it doesn't yet support custom tunes, or would I be better off to do other performance upgrades and just hold off on a tune for now? Does anyone have a pulsar and have any complaints? My other two ideas would be an exhaust or CAI. I plan on doing all three (or two if it's not worth it) within the year but which did you guys notice the most? Are there any other performance upgrades I should do besides those first? I have a 3.21 gear set but I dont plan on changing that until I get larger tires and a mild lift put on and see if I feel the need for that.
Sent from my SM-G965U using Tapatalk
Pull Ya
Cedar Creek, Tx
What are your goals and/or expectations from the truck?
Jay
Machoramdysavage
Americas
I’ve used both. Pulsar is a heck of a good bang for the buck. You will just have to sell it off when you decide to get serious doing stuff. It’s great for a stock vehicle tho.
I will make a video someday of a pull with the 91 diablo w/trans tune vs the pulsar level 8 I filmed a while back.
The diablo 91 tune 0-60 time is 5.6 seconds on my truck. The pulsar level 8 0-60 was a full second slower, which was still close to a second quicker than stock. Most of the gain in the diablo is in the trans tune. I’ll get a custom tune next and will be able to compare all.
Gas mileage got better with pulsar,
Mileage got even better with 91 diablo, also rpms are lower by a couple hundred when cruising down highway from what I noticed
Jho93
Jho93
Savannah, georgia
2019 classic
Jay
Well initially I'd just like the most I can get out of my truck without voiding the warranty. After that I'll see what I can think of. I've got my initial plans posted in another thread. Right now I just don't know where to start, because while I'm going to spend the money anyways, I'd like to prioritize them based off what I get back. I have a single side out exhaust so I know that a cat back dual will be noticable (and more fun to open up the throttle too)
Pull Ya
Cedar Creek, Tx
If you want to keep your warranty intact, then I think your idea of an exhaust and a CAI might be a good idea, although the stock intake system does a pretty good job. The CAI system that will provide the most performance gain is the Vararam. If you install a CAI and are forcing more air in you will also want to invest in a more free flowing muffler such as a Magnaflow or something similar. One other thing you might consider is a Pedal Commander. It will take all the "lag" out of your acceleration and give you a much more responsive feel. You will not gain any hp or torque however. It is more of a "fun" factor to many of us--it makes your truck more fun to drive. Another mod you might consider is a catch can. It will keep a lot of crap out of your engine and will keep your throttle body cleaner. These are a few initial things you can do to make your truck a little more responsive. The two biggest bang for the buck mods are the tuner and a set of long tube headers however you may run into some warranty problems with those mods.
Jay
Jho93
Jho93
Savannah, georgia
2019 classic
Okay cool I was actually looking at the s&b intake over the varram, but I'll definately take a second look at it. And yeah I was gonna wait on headers but I was actually leaning more towards the tuned length over the long tubes just so I didn't lose too much on the low end especially since I'm not really sold on changing the gear ratio and when I upsize the tires it I dont want it to be a dog down low. Do you happen to know about the tuned length vs long tube. I was planning on doing a little research here soon, but experience will tell more than a stat sheet printed by the manufacturer.
Jho93
Jho93
Savannah, georgia
2019 classic
Pedal commander is on my list as well but it's just not at the top of my list. It will probably be the next thing after these upgrades.
Pull Ya
Cedar Creek, Tx
I have not had any experience with the "shorty" headers. Is your truck a 4x4?
Jay
Pull Ya
Cedar Creek, Tx
You might do some research regarding your possible gear swap. I not sure you will like what you find---
Jay
Nick@GotExhaust
Supporting Vendor
SC
Jho93
Jho93
Savannah, georgia
2019 classic
Jay
Yeah that's why I'm not sold on regearing the truck because I need a whole new front dif and then regear the rear from what I can tell
Jho93
Jho93
Savannah, georgia
2019 classic
That's awesome, thank you, and have you had any customer complaints on the pulsar?
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
welcome from another Classic owner.
I love the Pedal Commander, but the Pulsar can pretty much do both, add power 6-8 and help off throttle response. So two birds with one stone.
If you order the Pulsar, get part # 32453, I accidently got the 32451, for 15-18
But simple, the Pedal Commander is easy to install, makes it fun to drive!
Jho93
Jho93
Savannah, georgia
2019 classic
I've heard of people running both and I'm sure I will eventually just to have more control over the throttle sensitivity but I was thinking the pulsar has a little bit of throttle improvement as well so it would cover a lot more. I wish the pulsar would get custom tune support already.
Jho93
Jho93
Savannah, georgia
2019 classic
Is the module actually different for a 19 classic than a 15-18? I could understand a new body style 19 but not the classic
Graygoose
Oklahoma
Convert, for now.
small
yes Its different per Edge
Machoramdysavage
Americas
I’ve used same pulsar unit on 18’ and 19’ classic with no issues.
Jho93
Jho93
Savannah, georgia
2019 classic
I cant imagine they changed the pcm for the classic or implimented a drastically different software than 2018 so that's surprising but I guess they could just be telling you that to to sell another one or there could be minor programming differences
