Hudson
So I tackled my first oil change today on my 2018. I have watched oil change videos and read most of the forum instructions.
The truck was level, I let the oil drain from the pan for 15 minutes (top cap was off and the oil dipstick was removed)
I went to start to unscrew the oil filter and about half way while un-screwing i saw oil drips on the outside of the filter. I screwed it back up and waited 5 more minutes. Tried again, same thing. This time i unscrewed the filter completely off, put a plug in it and took it out. Had to wipe off oil from the frame and the catch piece of plastic above the axle.
My question is why is my experience different than every video I watched that claims no oil will spill from the filter once it is unscrewed?
Did I not wait long enough?
Did I warm up the truck to much and made the oil too thin?
Should I be bagging the filter before unscrewing with a Ziplock?
Your expertise would be greatly appreciated.
