17RamDude
I watched many You tubers doing transmission fluid change. Some said that you don't have raise the rear of the truck to level off the transmission. Others said you have to. I lifted the rear and replace my transmission pan and filter used a aluminium pan. I followed the green sheet and added 8 quarts of fluid. Did I do this right?
